Is the Wyze Band scratch-resistant?
Yes, it's Gorilla Glass.
Wyze Band's AMOLED screen is  covered by a 2.5D Corning Gorilla Glass, which gives it level 7 Mohs hardness against scratching with normal usage. Also, the surface is slightly curved so you can see the screen from all angles.
It's smudge-proof, too.
On the glass, we've applied an extra layer of anti-fingerprint coating. That means no more fingerprints stuck on the screen, easier finger-touch control, and even more scratch resistance.
Don't subject the Wyze Band screen to abrasive or corrosive objects like keys, metal coins and sand.
Still need help?
