Can I export my Wyze Scale data?
Yes, in your Scale Settings.
  1. In the Wyze app, tap on your Wyze Scale.
  2. Tap on the Settings gear > Export Data.
  3. Select the data range (the past Week, Month, Year, or Custom range).
    1. If you tap a Custom range, set a Start and End Date.
  4. Tap Export, the OK.
Have Apple Health or Google Fit? You may also be able to export your data from those sources instead.
Still need help?
