How long is the Wyze Cam Outdoor's battery life?
Up to 6 months.
With normal use, the Wyze Cam Outdoor's rechargeable battery should last 3-6 months before recharging.
Note: If you're experiencing poor battery life, check out Troubleshoot Wyze Cam Outdoor battery life issues.
Tips for better battery life:
  • View the Live Stream only as needed.
  • Use Scheduled Recording sparingly.
  • Use Time Lapse sparingly.
  • Place the camera in a low traffic area if Motion Detection is enabled.
Still need help?
