Yes, but we don't recommend it.
The Wyze Cam Outdoor can work on continuous power (plugged into a power source, instead of using the battery), but we do not recommend it. This is because continuous power requires you to pull the rubber cover off of the charging port, which would leave the camera vulnerable to damage.
If left plugged into power, the camera would no longer be weatherproof.
