What's the difference between the Wyze Cam Outdoor and v2?
It's wireless, weatherproof, and battery-powered.
The biggest difference between Wyze Cam Outdoor and the Wyze Cam v2 is that it's weatherproof (IP65 rated) and wireless with a built-in battery. The outdoor camera also features a PIR sensor for motion detection, instead of the v2's pixel comparison algorithm.
Wyze Cam Outdoor excels in all environments - from extreme cold to extreme heat. In addition to using the camera outside of your home, Travel Mode lets you use it without WiFi access. That means you can take it with you anywhere
