It depends on the amount of damage.
If your Wyze Cam was twisted up in a tornado, whisked away in a flood, or otherwise extremely injured, it's likely that the camera cannot connect to the cloud. No connection to the cloud = no recordings saved to the cloud.
But if the damage is minimal, and you can still connect to the camera in the Wyze app, your video should be saved to the cloud.
