My camera with Cam Plus only records 12-second videos.
Problem
You have Cam Plus, and instead of recording full-length videos showing the entire event, your camera only records 12-second videos.
Troubleshooting
  1. Check that your Wyze app is up to date.
    1. In your Wyze app, navigate to the Account tab > tap About.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
  2. Check that your Wyze Cam’s firmware is up to date.
    • You can check this by going to the Account tab > Firmware Update.
    • If there is an update available for the camera, please move forward with updating it.
  3. Make sure the camera is set to record correctly.
    1. Navigate to the camera’s live stream > settings > Event Recording > toggle on Record Motion Events.
    2. Enable AI Events Only then tap Smart Detections and select the desired options such as Person or Vehicle.
  4. Unassign the Cam Plus license from the device and reassign it back.
      • You can do this in the Wyze app by going to the Account tab > Services.
  5. Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
  6. Restart your camera.
    • This can be done in the camera’s settings > Restart Camera > Restart.
    • Note: This option is not available for Wyze Cam Outdoor or Wyze Video Doorbell devices.
If you're still experiencing issues, send a device log to our engineers for review. To send a device log, go to the camera's livestream > Settings > Wyze Support > Submit a Log.
Still need help?
