Is Cam Plus available on Wyze Cam Outdoor?
Yes, Cam Plus is supported on the outdoor cam.
Wyze Cam Outdoor allows for adjusting both the Recording Length and Recording Cooldown so that you can either record the full duration of motion, or end the recording after a set amount of time (or add a gap between recordings) to help reduce the impact that this has on your Wyze Cam Outdoor's battery life. These can be changed under Wyze Cam Outdoor > Settings > Event Recording.
Backup to Base Station is unavailable when using Cam Plus with Wyze Cam Outdoor.
