Wyze Video Doorbell includes Night Vision, similar to what you're already using on your other Wyze Cam devices. This feature lets you view an area even in deep shade or darkness.
To turn on Night Vision for Wyze Video Doorbell:
- In the Wyze app, tap on your Wyze Video Doorbell.
- Tap the Settings
gear on the top right, then Advanced Settings.
- Under Night vision LED, note the Off, Auto, and On options.
- Auto will automatically turn Night Vision on and off as needed.
- Tap On to turn on Night Vision LED.
What is the White Light LED?
There is an additional LED light bar on the front of the Wyze Video Doorbell below the camera lens. When enabled, this light will turn on automatically in dim light to help capture a clear face when a person is detected.
To turn on auto White Light LED:
- Tap the Settings
- Next to White Light LED, tap the toggle to On
- Tap the toggle to Off to disable the White Light LED.
