Worried you won't see clear faces in the dark? Your doorbell has an LED light that will automatically turn on when motion is detected in dim light. This setting can be enabled and disabled in the Wyze Video Doorbell's Advanced Settings.
To turn on the White Light LED:
- In the Wyze app, tap on your Wyze Video Doorbell.
- Tap on the Settings icon
on the top right, then Advanced Settings.
- Next to White Light LED, tap the toggle to On
- To turn off the LED, tap the toggle again.
