With your Wyze Video Doorbell, you have the ability to speak and listen to visitors using the doorbell's built-in microphone and speaker.
To speak through your video doorbell:
- In the Wyze app, tap on your Wyze Video Doorbell.
- Tap the Speak (microphone) icon
- The Speak icon will change color, and you will see Speaking displayed on your Live Stream.
- Sound will automatically be turned on.
- When you're done speaking, tap the microphone icon again.
- This will turn off both Speak and Sound.
To listen through your video doorbell:
- Tap the Sound (speaker) icon
- The Sound icon will change color.
- When you're done listening, tap the speaker icon again.
Note: It is not possible to change or control the volume of the audio produced or recorded by the camera's speaker and/or microphone.
