Can you adjust the noise cancelling level?
Yes, from the Wyze app and headphones.
There are three noise cancellation levels you can switch between:
  • High Active Noise Cancellation (ANC): With 40db noise reduction, outside noise is reduced to a whisper, so you can tune out the world.
  • Low Active Noise Cancellation: Outside sounds are audible, but still low.
  • Transparency Mode: Let's the outside world in, as if you're not wearing the headphones at all. Your audio is lowered, and outside sounds are amplified.
From the Wyze app:
You can switch between High ANC, Low ANC, and Transparency Mode on the headphones screen in the app. Simply tap to open your Wyze Headphones, then swipe left to right / right to left on the screen.
On the headphones:
You can switch between Active Noise Cancellation and Transparency Mode directly on the headphones. On the left earcup, single press the button. You'll hear a voice prompt with the mode you've entered.
Still need help?
