Wyze Cam v3 uses 5V 1A DC of power.
Wyze Cam uses 5V 1A DC power through a micro USB port. The included adapter is rated for 100-240V input, so you can use it with any power source within this range. The power consumption is between 2-4 watts, depending on whether Night Vision is turned on.
