How do I identify my spray head type?
Spray head type influences the precipitation rate and efficiency. You're required to set your spray head type for each zone during setup.
To identify your spray head type:
In the app, you can go to Spray Heads and click the information (i) icon next to each type to help you decide which type of spray head is in each zone.
Need to change your spray head type? In the Wyze app, tap on your Wyze Sprinkler, then select your Zone. Tap Spray Heads.
Still need help?
