Set limits for your vacuum.
In the Wyze app, you can create Virtual Walls to prevent the Wyze Robot Vacuum from going out-of-bounds, or from entering areas that don't need to be cleaned.
To create a virtual wall:
- In the Wyze app, tap on your Wyze Robot Vacuum.
- On the bottom right of your map, tap the square edit icon
- Tap + Add a virtual wall.
- Tap and drag the red square to move it, and pinch to resize it.
- Tap OK to save your virtual wall.
