Does Wyze Robot Vacuum work on wet floors? Brenda February 24, 2021 05:05 No, the vacuum should only be used on dry surfaces. Wyze Robot Vacuum should only be used on dry flooring. It is not a wet/dry vacuum, and is not meant to be used on wet surfaces. Using the Wyze Robot Vacuum on wet surfaces could damage the device.
