Yes, but it depends on the format.
Wyze Cam v3 is compatible* with microSD cards in formats FAT32 and exFAT.
FAT32: Wyze Cam v3 supports cards size 8GB, 16GB, and 32GB.
exFAT: Wyze Cam v3 supports cards size 64GB, 128GB, and 256GB**.
* This compatibility is only available using Wyze Cam v3 firmware 4.36.8.15 or newer.
** We have tested with cards up to 256GB when formatted as exFAT. Even larger cards may work, but this has not been tested on our end.
