Wyze Cam v3 is similar to all Wyze Cam devices (including v2 and the outdoor cam), but it has many features that make it stand out from the rest.
Wyze Cam v3 comes with:
- Excellent Color Night Vision with only a tiny bit of light needed.
- Starlight CMOS Sensor for clear viewing in super low light.
- Wired, not wireless or battery-powered.
- Does not require a Base Station for WiFi connectivity.
- IP65 weather-resistant, specifically made for indoor and outdoor use.
- Dual IR Light System, for better indoor infrared lighting.
- Ability to add accessories, like the Spotlight kit.
Wyze Cam Outdoor is not too shabby, and still full of unique features. Our favorite: WCO can go virtually anywhere, wirelessly.
Wyze Cam Outdoor comes with:
- Totally wireless, and can be mounted anywhere.
- PIR sensor for the best motion and person detection.
- Battery-powered, no need to run wires.
- Uses a Base Station for WiFi connectivity.
- Specifically designed for outdoor use, can handle extreme weather conditions.
- Travel Mode lets you use your camera without Internet. You can literally take it hiking, camping, or set it up as a trail cam, and still be able to connect to it.
