You can turn your Wyze Cam v3 either on or off through the Wyze app. This will allow you to keep the Wyze Cam plugged in, and use the Wyze app to turn it on/off. There are a couple of different places where you can do this.
To turn the Wyze Cam v3 on/off from the Home tab:
- Open the Wyze app
- Tap the On or Off button to the right of the camera's device listing
- The On/Off button will reflect the current state of the camera
- The On/Off button will only be available when the camera has a stable IoT connection to our servers. Otherwise, the camera will be listed as "Offline" with a crossed-out cloud symbol. This isn't representative of the camera's live streaming capabilities and only reflects whether the camera can be affected by automation or instructional commands.
To turn the Wyze Cam v3 on/off from within the Live Stream:
- Open the Wyze app
- Tap the camera on the Home tab to enter its Live Stream.
- Tap the
button under the live stream window
- Tap Turn on or Turn off
It's worth noting that turning the camera off from within the Wyze app won't take it entirely offline. Since the camera needs to be able to receive an "On" command whenever you decide to turn it back on, it will maintain an IoT-level connection with our servers. The Live Stream and Event recordings (cloud uploads) will be disabled completely while the camera is turned off this way.
Note - While turned off through the Wyze app, if your Wyze Cam loses its network connection or loses power, it will reconnect in the "On" state whenever the network/power is restored.
