The Wyze Cam v3 comes with a number of different mounting options depending on your needs.
Related article: Wyze Cam v3 Mounting Guide
Magnetic Mounting
Just like with the Wyze Cam v2, the v3 includes a magnet in its base that allows it to be mounted to steel or iron surfaces. To help create more opportunities for this we included a metal plate with an adhesive backing just like we did with the v2.
Screw Mounting
If you want a more secure mount, using the included screw kit can help make sure the Wyze Cam v2 has a solid connection with whatever surface you mount it to.
1/4"-20 Mounting
Like with the Wyze Cam Pan and Wyze Cam Outdoor, the Wyze Cam v3 has a `1/4"-20 threaded connection that you can use to mount the cam to any standard 1/4"-20 mount.
