You can select which camera capabilities trigger an alert in Wyze Home Monitoring Service: motion, person (Cam Plus or Person Detection required), and CO/smoke alarm smart sound detection.
This setting is per camera. You can set the camera on your front door to notify you only when a person is detected while the camera in your kitchen notifies you only when CO/smoke alarm sound has been detected.
How are notifications delivered?
The message will be delivered to you via the same channel regardless of the detection settings—Critical Alert (iOS), push notification (default), or you can turn notifications off.
Choosing the right trigger and format for the Security Camera notifications will maximize the value you get from Wyze Home Monitoring Service's camera experience.
