Yes, it works with most Wyze Cams.
You can use the Wyze Entry and Wyze Motion Sensors to control other Wyze products. For example, you can create Rules in the Wyze app to turn on Wyze Bulbs when an Entry Sensor opens or a Motion Sensor is triggered.
