We have a few suggestions to help:
Install the motion sensor using the instruction from the manual, especially if your family has pets.
Train all home members and users on how to use the system, including babysitters and visitors.
Secure doors and windows before arming.
Remember your PIN so you can disarm the alarm quickly.
Remember your Safe Word so that you can cancel the alarm when the monitoring center is verifying with you.
Periodically check if the sensors are attached to windows and doors firmly.
