No, those cameras can only trigger an “alert.”
Cameras assigned to Wyze Home Monitoring’s Security Camera list can only trigger an “alert”—a message delivered to you in the format you choose. You can select which Security Camera capabilities will trigger an alert.
An “alarm” means an on-duty sensor has been triggered and the Wyze Home Monitoring system was not disarmed via PIN within the entry delay. By default, an alarm will trigger the siren to sound, and contact Noonlight to verify if first responder dispatching is needed.
