Your monitoring system will continue working normally.
Wyze Keypad is just an input device, which means it doesn’t process rules or save data. So if the keypad is disabled, destroyed or stolen, your system will work as usual.
Wyze Sense Hub is where sensor (including Keypad) data is aggregated and routed to the Wyze server, and it’s also where the siren is.
Even further, as we have dual-countdown mechanism, after someone triggers a sensor, even if the hub is also destroyed, you and the monitoring center will still be notified of the alarm.
