Wire detection error: Wire not found.
Problem
In the Wyze app, you've selected a wire that doesn't have a corresponding terminal. The app says "Wire not found."
Solution:
  1. The wire detection operation is completed when the device first powers up. Remove the device and try reconnecting the device.
    • Wait at least 30 seconds while the device reconnects to the server.
  2. Attempt the wire connection again, make sure the wire connection is secure
    • Go to control board and verify that the wire is securely connected
    • Wire not connected at the control board? This wire is unused and can be removed from the thermostat connection, and unselected in the wire selection screen during setup.
Still need help?
