Zone Control isn't working with Wyze Thermostat.
Wyze Thermostat is compatible with most zone control systems, including zone systems with dampers. However, the thermostat uses standard thermostat connections. Proprietary connections such as DAMP or MISC, are not compatible with Wyze Thermostat.
  • Zone Panel: Wyze Thermostat is compatible with zoned system panels
  • Master/Slave: HVAC systems that utilize the master/slave communication configuration may not be compatible with Wyze Thermostat.
Still need help?
