Auto-pause isn't working on my Wyze Headphones.
Problem
You have Auto-Pause selected in your headphones Settings, but it doesn't auto-pause your content as expected. You remove your headphones, but the content continues playing instead of pausing.
Troubleshooting Steps
  1. Update to the latest Wyze Headphones firmware.
  2. Double-check that you have Auto Pause enabled:
    1. In the Wyze app, tap Wyze Headphones > Settings gear. Next to Auto Pause, tap the toggle ON.
  3. Power cycle your headphones:
    1. In the Wyze app, open your Wyze Headphones then swipe to turn on Private - High noise cancellation
    2. Turn off your headphones, then swipe to close the Wyze app.
      • Single press the round Power button on the right ear cup.
    3. Keep the headphones near your phone and wait about 10 minutes.
    4. Turn on your headphones.
    5. In the Wyze app, tap Wyze Headphones again.
    6. Play some content, and test Auto-Pause again. It should be behaving as expected.
Still need help?
