Start cleaning!
- In the Wyze app, tap on your Wyze Robot Vacuum
- Tap Clean.
- Allow the vacuum to complete a full clean and return to the charging station on its own.
Wyze Robot Vacuum needs to do an initial clean to navigate and scan your space. Once you've run the vacuum for that first clean, and it's returned to the charging station, you'll see your map in the Wyze app. You can only have 1 map at a time.
Tip: Before starting the first clean, prepare your space by picking up any small obstacles from the floor. Small toys, dropped blankets, and other movable objects can result in an incomplete map.
