How do I split a room?
To split a room:
  1. In the Wyze app, tap on your Wyze Robot Vacuum.
  2. Tap the pencil icon.
  3. Tap Customize rooms.
  4. Select the room you want to split. Tap Split.
  5. Tap and drag the circles on the line to set where the room splits.
  6. Tap OK.
Can I split a smaller area within a room?
No, you can only split a room from boundary wall to boundary wall. You cannot split a room within interior walls, like split a smaller area within a larger room.
Example: The red area below is a kitchen island. You cannot split this small area, only the entire room.
Still need help?
