How do I clean Wyze Handheld Vacuum?
Cleaning the handheld vacuum involves emptying the dust cup, and rinsing the filters with water.
To clean Wyze Handheld Vacuum:
  1. Empty the dust cup.
    1. Point the handheld vacuum at a trash can and single press the quick release button.
    2. Shake out the debris into the trash.
  2. Clean the HEPA filter and pre-filter.
    1. Rotate and remove the dust cup, then rotate and remove the prefilter gauze.
    2. Pull the HEPA filter out of the prefilter gauze and rinse both with tap water. Let dry.
  3. Once dry, reassemble the vacuum.
  4. Close the top of the vacuum with your hand.
Still need help?
