How do I merge rooms?
If you want to merge two rooms into one, edit the map in your Settings.
To merge two rooms:
  1. In the Wyze app, tap on your Wyze Robot Vacuum.
  2. Tap the pencil icon
  3. Tap Customize rooms
  4. Tap the rooms you want to merge.
  5. Tap Merge.
    • Note: You will not be prompted to confirm the merge.
Still need help?
