We are investigating this issue. Please submit a log.
Problem: You've created a virtual wall, which is supposed to be a barrier the vacuum avoids. Wyze Robot Vacuum goes beyond the virtual wall anyways.
We are still working on a solution to this issue. To help our engineers investigate what's going on, please send us a log from the Wyze app.
To submit a log:
- In the Wyze app, tap on your Wyze Robot Vacuum.
- Tap on the Settings gear.
- Scroll down and tap Submit a Log.
- Select Incorrect cleaning area as your issue category
- Add details to your log, then tap Submit.
- On the last screen, find your Log ID and save it.
- This is important. The Log ID comes in handy for our support team and engineers to locate your device's specific logs when troubleshooting.
