I can't use decimals when setting a Usage Reminder.
Problem
You're trying to set a Usage Reminder in your Wyze Plug Outdoor Settings, but you see "must be between 1 to 1500 integer" when you try to Save your settings.
Sorry about that!
Currently, the Usage Reminder feature only supports integers, or whole numbers. You can use numbers like 30 or 460, but not 50.5 or 1300.8.
Still need help?
