Can I use Wyze Bulb Color if my WiFi drops?
Yes, but with fewer functions.
Wyze Bulb Color has both a WiFi and Bluetooth connection, so if your WiFi goes out, you can still locally control your lights via the Wyze app.
Without WiFi, you can control Wyze Color Bulb from its product page in the app, but you can't turn it on/off from the Home screen. Also, Rules and voice commands will not work.
Still need help?
