My Wyze Bulb Color turns on randomly.
Problem
Your Wyze Bulb Color turns on unexpectedly, without you turning it on yourself.
Troubleshooting
  • Check if you have Sleep Routines enabled.
    • In the Wyze app, tap on your Wyze Bulb Color > Settings > Sleep Routines.
  • Check your other automations, like schedules, and rules.
    • If you have any automations enabled, they could be set to turn your bulbs on and off automatically. This could be during specific times (Schedules) or if triggered (Rules).
    • In the Wyze app, tap on your Wyze Color Bulb > Settings > Schedules & Automations.
  • Check with your Shared users, who can control your bulbs in the Wyze app.
  • Check if you have any IFTTT Applets set up.
  • Make sure your bulbs aren't in Vacation Mode.
    • In the Wyze app, tap on your Wyze Color Bulb > Settings > Vacation Mode. Set it to Off.
  • Check your other Wyze Bulbs, if you have any installed. Are they affected, too?
    • If all bulbs are affected, network stability or power fluctuations might be causing the issue.
      1. If you have an ASUS brand router, try disabling Airtime Fairness. (Learn more here)
    • If only 1-2 bulbs were affected, check the range of the Wyze Bulb Color to the router.
Still need help?
