Can I use multiple color bulbs in one fixture?
Yes! And you can add them all to one group for easy controls.
You can use multiple color bulbs in one light fixture. For daily use, you can use a light switch to turn them all on / off at once, or create a group to control them together. But if you want to change the settings, you'll have to tap on each bulb separately in the Wyze app.
Still need help?
