When setting up your Wyze Video Doorbell, you were prompted to add a Wyze Chime. If you skipped this step, follow the steps below to set up your new chime.
To pair your Wyze Chime:
- In the Wyze app, tap on your Wyze Video Doorbell.
- Tap on the Settings gear on the top right.
- Tap Accessories > + plus sign.
- Tap Next.
- Plug your chime into a standard power outlet.
- Under the chime, press and hold the reset button until the blue light begins flashing.
- Tap Finish.
- You may have to tap the back arrow to see Wyze Chime in your Accessories list.
