There isn't any Weather data on my Wyze Watch.
Problem
You tap on the Weather app on the watch and no weather data displays. You see "No Data."
Troubleshooting Tip:
If your Wyze Watch is disconnected from the app, it cannot load weather data. Sync to the app and you should be all set.
  1. Make sure Bluetooth is enabled on your phone.
  2. In the Wyze app, tap on your Wyze Watch.
  3. Let the Wyze app sync and connect to your watch.
Still need help?
