How do I replace my Wyze Watch strap?
You'll need:
  • Wyze Watch replacement strap x 1
  • Wyze Watch x 1
To replace your Wyze Watch strap:
  1. Turn the watch so that the underside of the body is facing up.
  2. With your fingernail, push the pin down and pull the strap outward.
  3. Push the replacement strap into the strap socket.
    1. Align the new replacement strap's pin with the hole on the watch body.
    2. Push the pin down and push the strap inward until fully inserted.
    3. Repeat this action on the other end of the watch.
  4. Tug the watch to make sure the straps are secure.
  5. You're all set!
Still need help?
