How do I add a new sensor after setup?
If your Wyze Home Monitoring system is all set up, but you want to add another entry/exit sensor or motion sensor, follow the steps on this page.
To add a sensor to Wyze Home Monitoring:
  1. In the Wyze app, tap Monitoring.
  2. Scroll to the bottom of the Monitoring screen and tap Home Monitoring Settings.
  3. Tap Home & Away > Add New Sensor.
  4. Select the sensor you want to add, either:
    • Wyze Entry Sensor v2 OR
    • Wyze Motion Sensor v2
  5. Remove the plastic battery tab from your new sensor.
  6. Tap Next in the Wyze app.
    • Your Wyze Sense Hub will say "Ready to connect"
  7. Press and hold the reset button on the side of the sensor until the status light flashes.
    • Your Wyze Sense Hub will say "Pairing successful."
  8. Enter a name for your new sensor, or choose from one of the Suggestions.
  9. Tap Finish.
  10. Tap Finish again.
You must assign your new sensor to Home and Away modes for it to be listed as a sensor for your system.
  1. From the Home & Away screen, tap Edit
  2. Tap to check the box next to your new sensor on Home and/or Away modes.
    • Select the mode at the top of the screen.
  3. Tap Save.
Still need help?
