I have 2 doorbells and 1 chime. Can I replace both with Wyze Video Doorbells?
Yes, with the correct power supply.
Two Wyze Video Doorbells would require 16-24 V and 10 VA power supply from your existing mechanical chime circuits. Please check if your transformer is 16-24 V and at least 20 VA.
If your power supply is correct, please follow these steps for installation:
  1. Turn off the power supply to the doorbell system from the house's power panel.
  2. Remove all three wires from the mechanical chime and connect them with the Wiring Cap,
  3. Your old mechanical doorbell buttons with Wyze Video Doorbells.
    • If you are not familiar with this step, please follow the in-app setup process.
  4. Turn the power supply back on and check if the doorbell is powered, flashing yellow and says "ready to connect."
  5. Follow the in-app setup process to add each doorbell to your Wyze account.
Still need help?
