Problem
While using the Wyze app to set up Wyze Home Monitoring, you finished a step but cannot navigate backwards to it. You can only continue forward.
Troubleshooting
We're sorry about this! This is a technical issue that we hope to resolve in an upcoming app release. In the meantime, note the settings that you need to change and continue the setup process.
Once complete, on the Monitoring tab tap Home Monitoring Settings. Tap the area you need to update your settings for directly.
