The remote can be up to 50 feet away from Wyze Floor Lamp.
You can use the remote up to 50 feet away from the lamp, connected via BluetoothⓇ. This may vary depending on if there are any obstacles in the way, like walls, doors, and furniture.
Happy Holidays 2023! The holidays are upon us, and you may experience longer than usual wait times. Our support team appreciates your patience while we work through this busy holiday season! ❄️
