BluetoothⓇ Remote Fine-tunes 11 Levels of Brightness. Wyze Floor Lamp includes a Bluetooth remote that lets you pair, turn on/off, and adjust the lamp's brightness.
Super Focused 23° Light Beam. Focus light exclusively on your work without disturbing others around you.
High 90+ CRI. Color Rendering Index (CRI) measures how close a lightbulb’s light is to natural sunlight. A 90+ CRI rating means colors will look more natural under its light.
Smart Lamp with Wyze App Accessibility.Connect to the Wyze app for more features including a remote control, schedules, delay timers, and smart dimming.
Unique 5’11” Flexible Gooseneck. The lamp has a 5’11” flexible lamp neck that allows you the light up anywhere you want.
