Skip to main content
How do I factory reset Wyze Floor Lamp?
Brenda
To factory reset Wyze Floor Lamp:
- Toggle the power switch on the cord 5 times.
- The light will pulse briefly when the lamp is successfully reset.
To factory reset the Bluetooth remote:
- On the back of the remote, open the battery cover.
- With the battery still installed, press and hold the reset button for at least 3 seconds.
- The status LED will flash, then steady when it has been successfully reset.
Have more questions?
Submit a request
