How do I check the battery level?
Check the battery % in the Wyze app.
  1. In the Wyze app, tap on your Wyze Buds Pro.
  2. Tap the Settings gear.
  3. The battery levels are at the top of the screen.
Note: A “Low Battery” audio prompt will play when your buds reach 20%.
Was this article helpful?
0 out of 0 found this helpful
