Detailed Troubleshooting for Wyze Watch Notifications
If you are missing some or all Wyze notifications on your Wyze Watch 44 or 47, follow the detailed instructions below to troubleshoot.
Detailed Troubleshooting Steps on iOS (see below for Android)
1. Check if your phone is paired to the watch via Bluetooth.
  1. Tap to open your Wyze Watch in the app, then tap “Pair” on the Bluetooth Pairing Request pop-up to pair your Wyze Watch to your iPhone.
  2. Check your iPhone’s Bluetooth settings and tap the info icon for Wyze Watch 44/47.
  3. Tap to toggle on "Share System Notifications".
    • If you cannot find Wyze Watch 44/47 in your Bluetooth settings, please restart your Wyze app and pair again.
2. Check if the notification toggle in the Wyze app has been turned on.
  1. On the Wyze app Home tab, tap on your Wyze Watch 47.
  2. On the Wyze Watch 47 page, tap “Notification” then tap to toggle on Allow Notifications if you want your Wyze Watch to send notifications to you.
  3. Tap the toggle on for each application you want to receive notifications from.
    • If you cannot find an app in the list, tap to allow notifications from “Other applications” at the bottom of the list.
3. Check the time range of the Wyze app's Do Not Disturb Mode setting.
  1. On the Wyze app Home tab, tap on your Wyze Watch 44/47.
  2. On the Wyze Watch 44/47 page, tap “Do Not Disturb”.
  3. On the next screen, tap to toggle on "Do Not Disturb" and set a start and end time.
When Do Not Disturb is turned on, your Wyze Watch will not display incoming notifications as pop-ups. Instead they will be put in the notification center, which you can access by swiping down on the home screen of the Wyze Watch.
4. Check if the watch's Do Not Disturb Mode is on.
From the home screen of your Wyze Watch 44/47, swipe upwards across the screen. You will see a control center with multiple shortcut functions.
  • The grey bell icon indicates that Do Not Disturb Mode is turned off, which means your Wyze Watch will display a pop-up and vibrate to let you know when you have a new notification.
  • The blue, crossed out bell icon indicates that Do Not Disturb Mode is turned on, which means your Wyze Watch will send incoming notifications to the notification center without disturbing you.
You can tap on the icon to switch Do Not Disturb Mode from off to on.
5. Check your system notification permissions.
If you are still not receiving notifications from your text or SMS messages, check your Notification settings for Messages on your iPhone. Be sure to allow alerts for “Lock Screen”, “Notification Center” and “Banners”.
Detailed Troubleshooting Steps on Android
Pair your Wyze Watch with your phone via Bluetooth.and connect the Wyze Watch.
  2. On the Wyze Watch 44/47 page, tap “Notification” and tap to toggle on Allow Notifications if you want your Wyze Watch to send notifications to you.
  3. Tap to toggle on each application you want to receive notifications from.
    • If you cannot find an app in the list, tap to allow notifications from “Other applications” at the bottom of the list. Your phone may ask for your permission to get access to your contact and other information, please allow the access through the pop-up or system settings.
    • When Do Not Disturb is turned on, your Wyze Watch will not display incoming notifications as pop-ups. Instead they will be put in the notification center, which you can access by swiping down on the home screen of the Wyze Watch.
4. Check whether the watch's Do Not Disturb Mode is on.
Please turn on notifications for the applications that you prefer to access under the notification settings in your phone. For example, if you want to receive notifications from Facebook, make sure to allow notification alerts, such as banners and other notifications.
Still need help?
