How do I check the battery level?
You can check how charged the battery level two ways:
  1. Plug the Main Unit into an outlet.
    • The LED screen will display the current battery level as a number from 0-100.
  2. Turn the vacuum on.
    • Same as above, the LED screen will show the current battery level.
Still need help?
