The Remote fails to setup
Presents as: The Bluetooth remote will not pair with the Wyze Floor Lamp.
Troubleshooting:
To set up the remote for the Wyze floor lamp:
  1. To set up the remote for the Wyze floor lamp:
    1. Toggle the cord switch to turn on the light.
    2. Install one AAA battery in the remote and pop out the side button. When the status LED light blinks yellow, it is ready to set up. (Note: Please start the setup process within 15 minutes.)
    3. Press the center button to pair when the bulb flashes.
    4. Push the side button back in when the setup is complete.
  2. Toggle the switch on the Lamp’s cord 3 times to reset it and try again.
  3.  The bulb will pulse briefly to indicate this was done successfully.
  4. Try factory resetting the remote:
    1. On the back of the remote, open the battery cover.
    2. With the battery still installed, press and hold the reset button for at least 3 seconds.
    3. The status LED will flash, then steady when it has been successfully reset.
